Pulling formula into work today, was on my way to winston speedway on saturday gettn on the highway,lost 4th and 3rd gear
gonna rip it out, and see what went bad... hopefully nothing too costly.
Formula down
Lurker- August 27th, 2008
- 452
- Anthony Z
- 1989 Trans Am GTa V8
- Muskegon, MI
- mechanic/quick lube tech
Sounds like a blown up 4l60. So.. Getting on the highway huh? I've never seen you get on the highway at less than full throttle. Doesn't like the 3 to 4 shift at wotOriginally posted by TORN View PostI'm curious what Trans is in that machine?98 z28, m6, monster clutch, eibach pro kit, custom twin turbo setup, 317 heads, z06 valve springs, arp rod bolts, 512rwhp at 10lbs. cobra eater
- Lowell, MI
- Meat Processor
sounds like the 3-4 clutch pack is toast. I wouldn't advise using the Raybestos Z Pak
- 452
- Anthony Z
- Muskegon, MI
Ordered rebuild kit from GM, 150$ tearing down trans now, burnt fluid, maybe get some pics up asap. 3rd 4th clutch pack is def. fried and the pcs is asking for 1amp and was getting 0amps which is why i have hard shifts from 1-2 and 2-3.
- 452
- Anthony Z
- Muskegon, MI
Over and forward clutch piston was cracked, and friction disc were burnt up. parts coming into 2day, and should be put together and in car tonight/tomorrow
tryn 2 upload pics at work... not sure if its going to work
- 452
- Anthony Z
- Muskegon, MI
while putting together tranny, found out it was missing 1steel and 2friction disc for the clutches
so someone has been in the tranny before. but goin back together today and on the road tonight
and book time calls for 12hrs and i onlhave 3into it so far
