help with gas lines (true dual/torque arm clearance)
  • #31
    I'm not sure on the fuel lines as I have yet to do that myself but I do know that the racetronix kit is a pretty safe bet as an upgrade to the pump itself or you could run one of the newer 340 pumps.
    • #32
      Hard part is finding all the fittings you need.
      Remember braided stainless hoses have rubber in them and they will break down over time and don't last forever. Teflon lined hoses will last longer but they'll cost you more.
      Another option is stainless hard line - normally comes in 25 ft rolls. Bend it the way you want and then terminate it with a/n tube nuts. It's not much cheaper than braided A/N line.
      Fuel systems aren't an area that you want to cheap out on. Trust me burns f'ing suck - nothing I'd wish on anyone.
      2000 Formula
      fixed slow junk
      • #33
        Agreed and exactly why im asking for help on this! Thanks for the info on braided vs hardline
        • #34
          I know Lonnie's performance offers a full kit - but it's like $1100 without the pump setup. Which is way to much imo.
          Quick google search found this - http://www.gmhightechperformance.com...use/index.html
          2000 Formula
          fixed slow junk
          • #35
            Is the racetronix the same form factor as the stock pump as far as lines/hardware?
            • #36
              Racetronix is basically a walbro 255 pump but they include upgraded wiring connectors.
              • #37
                The racetronix is a drop in replacement for a stock pump.
                • #38
                  http://www.hotrod.com/projectbuild/f...s/viewall.html
                  http://www.summitracing.com/parts/SUM-CSUM2401/
                  http://www.jegs.com/p/JEGS-Performan...56885/10002/-1
                  Find some diesel trucks at junk yards, and go to town.
