R1cefed's turbo build.
  • #46
    what motor mounts are you using?
    • #47
      Ask John Marcella to make out one lol.
      Good idea Jeff! John should have something like that done by Summer 2012!
      • #48
        I am using stock motor mounts....I didn't want to risk transfering any vibration to the car with poly or solid.
        About the elbow though that ***** will be a tight fit. I am really doubting even the edelbrock ultra low profile elbow I have on order will fit. ( I know it sucks but it wont be so bad pressurized I hope. Either way it is not max effort by anymeans if it costs me a couple hp to save hacking my car to death I guess I will live with it unless it is really horrible.
        I am impressed how well my STS system is going on the car....literally no hacking....every part/bent fits like a glove and assures me that its sealing properly. I really thought it would be a nightmare but its very smooth so far .... I will post pictures tomorrow when I get the car a little higher in the air.
        99ws6 - Huron Speed Turbo - PT67
        • #49
          The problem with those low profile elbows isn't the fact it might cost you a few HP. Its about air distribution. Just because the AFR reading in your exhaust says 12:1 doesn't mean the front 4 arent 8:1 and the back 4 arent 15:1. Last thing you want to do is have a few holes go lean. Tolerances are tighter with a boosted motor than anything when your trying to keep stock parts alive.
          • #50
            did you buy an ls1 STS kit? i bought an lt1 kit, and tried to make it work for my ls1. took a lot of fabrication (which i'm not good at). my car is lowerd. i had to raise rear to stock ride height to not scrape all over the place.
            • #51
              After doing some research I have learned that an elbow on a boosted setup is not the cause of distribution problems, on a n/a or nitrous setup I would never run one but you should be fine on a turbo car. I am willing to bet an elbow to fit under that area is going to rob a good bit of horsepower in itself I'd say at least 50rwhp.
              • #52
                4150 + carb hat FTW
                • #53
                  Damn you jeff don't tell me 50hp...ur going to make me chop my car apart.....if it is that bad I will have to weld one up over winter and just send this shit back.
                  I have a ls1 sts kit with the "750 "upgrade. .96 a/r and. 60 compressor. I will see how it does I am sure it will spool fast as hell. Just hoping I can get some rpm out of it.
                  • #54
                    I'm still just not getting why you didn't use a stock manifold guys have gone 8s on them they arent a restriction at that power level at all. Do some good research on low pro elbows they can be a huge restriction on the intake tract, buy one that is proven do not buy an ebay special
                    • #55
                      I may use the nitro daves elbow it looks most promising...I will be more than 8 psi I really don't want to hold it back with a shit elbow.
                      • #56
                        when you realize that the elbow wont fit and want to go to a ls6 intake let me know.. we could prob work out a trade between the two
                        edit... nvm i forgot your running L92's.. pretty sure the intake ports are different
                        • #57
                          Fast ls3/l92....Much cleaner, no hacking...
                          • #58
                            don't be surprised if you see the edelbrock for sale soon.
                            • #59
                              It would be best. Glad we could help
                              • #60
                                Stock 5.7 with 60-1 should run
