I knew it would happen, but it happened at the worst time. Last night at the Marshall Cruise as I was driving through down town the clutch pedal started to vibrate really bad when I pushed it in. Pulled into a parking space, figured it was too hot. A little bit later I tried to move my car to a better spot and all it did was squeak when I had the clutch pushed it. Turned it off. Now it wont even start.
Throwout bearing didnt get changed last time the clutch got changed, I am now dealing with the results. I believe I will be needing a new clutch, pressure plate and throw out bearing. Will I have to have the flywheel worked on?
Any advice? We will be doing this ourselves.
I want to put a stock- like clutch back in, the stage 2 RAM that was in it was too much.
