Im lookin to get some new parts for the TA but not to sure what to get. Currently I have LT Hooker headers with a full borla exhaust, with a cam that is mild, specs unknown. Suspension wise its been dropped, new race panhard bar and subframe connectors. Its never been tuned that I know of. The person who owned it prior to me drilled the throttle body hole out more to accomidate the cam. What could I get that will give the engine some more HP and TQ?
I want some new bolt on mods for my ls1
a tune would be a good place to start, but an LS6 intake would be my first mod and then have it tuned.Doing less with more
any paticular brand or just stock? I found this complete one on ebay the guy is from auburn hills too. what would be better a torque converter on the ls6 intake? http://cgi.ebay.com/ebaymotors/Compl...Q5fAccessories
all LS6 intakes are factory intakes, unless you wanna pay more for one from SLP. You should be able to find them on tech for $300-350 dont pay any more than that. I didn't know you were an auto, if thats the case a converter will improve your car MUCH more than an LS6 intake but both should be future plans. With either mod you'll want to get a good tune though.Doing less with more
Well that complete ls6 intake on ebay comes with the tb, injectors, rails, mao sensor and hardware. All for 438 free shipping. The throttle body I have now, the hole in the center was drilled out bigger to let more air in for the cam. If I got a tune would I need to replace the drilled TB? and what size injectors are stock on the ls1? These one's state they are 28lbs. Also if I was to go with the stall what would be a good number 2800-3200? I'd also have a spare TB to practice porting on.
the tb is the same, the rail and injectors are as well so all you need is the intake why waste money on the other parts? I believe all tbs have a small hole in them and having it opened up some shouldn't affect anything. You usually want to match the stall to the cam but since yours in unknown 3400-3600 is very common for most cars.Doing less with more
you should be just fine, I had a 90mm TB on my fast and it was drilled out big as well and it never caused any issues.Doing less with more
well as I mentioned a converter will wake up the car much more but your going to need a retune after, you could run the LS6 intake as is and save for a tune after but thats your choice.Doing less with more
