i believe its the crank sensor cause it seems like its not firing in sync with the coil packs, does anyone know where the crank sensor is located at?
need opinions on whats wrong with my ls1 engine
The crank sensor should be on the driver side toward the rear of the motor just above the oil pan.Doing less with more
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
Sounds to me, you should swap a lt1 engine in there so you have the dependability of optispark. LOLsigpic
well i found the problem, apparently the o2 sensor wired touched the header and melted all the wires together so i unplugged it and now its running good just waiting on the new o2 sensors i ordered, should have them tuesday
Pacesetter LT Race Headers, Volant CAI, 3.23 gears, Still working on it.
Good job though you found the problem. Burnt wires always makes things act strange and hard to find sometimes.MSD 8.5mm Superconductor wires w/ NGK $68 delivered, custom length LS1 LT1.HKE Precision Racing Engines 347-506 cid N/A, N2O, FI applicationsAFR, TFS, All Pro, Edelbrock, Dart head cam specialsRon Davis Racing.. radiators and heat extractors finest in the business
