everytime it rains or snows my engine misfires and stalls constantly, i dont know whats causing it but i could use some info, i am gonna start tearing the engine apart to make sure nothing is broken
need opinions on whats wrong with my ls1 engine
Plug wires.Originally posted by Jays99Camaro View Posteverytime it rains or snows my engine misfires and stalls constantly, i dont know whats causing it but i could use some info, i am gonna start tearing the engine apart to make sure nothing is broken
With the motor running get a spray bottle filled with water and start wetting the wires down and I bet you will recreate the exact symptoms you are describing.
i strongly agree amd soapy water works even better or you can just grab the wires while its running im sure youll know which ones are bad
Lsx swapped
Alright well 02 sensors only get used when the car hits closed loop and will not cause a no start. A car will still run with a dirty/bad maf sensor but it'll run like crap. It's starting to sound like you need to get a scanner on it to check all your sensor ranges and see if there operating correctly. Check fuel pressure also or atleast listen to hear the pump kick on. How many miles are on the car?Lsx swapped
i thought it might have been the fuel pump but i checked it yesterday and its working good, i came to the conclusion that the wires are good cause like you guys said if the car is misfireing the engine light would be flashing and it wasnt so something else is causing it to not start, i'm gonna change the plugs again today, things i'm guessing on would be the crank sensor, the computer, or the coil packs, it could also be the fuel injectors, cause it sounds to me like it wasn't misfiring but starving for gas i don't know. one thing is i tried to start it again and all i can smell is gas, very rich smell too, does that mean anything?
Pacesetter LT Race Headers, Volant CAI, 3.23 gears, Still working on it.
hold the gas pedal to the floor and try to start it, the injectors may be dumping fuel and that will kick the computer into a flood mode where the injectors don't fire only the coils will.Doing less with more
