Car runs fine, new fuel pump, Ignition module, water pump. Few days ago I made a sharp right there, can kept running but RPM's dropped to zero and stayed there, car woudn't accelerate for a few seconds and then it kicked back on. Eventually it got worse and worse til it would start and run but only idle at 200 sounding like it was only firing on 2 cylinders. I couldn't figure it out. It was throwing a P1361 code which is a Ignition Coil B secondary Circuit, dropped it off at the shop and they cleaned some connections and deleted the codes. But now it runs great all the time, But it still does it when i go around right corners. When I go around left corners she pulls strong as ever.
Now when I go around ONLY RIGHT CORNERS the car will stumble, backfire and maybe stall. I can start it right back up with no problems or hesitation. I think there may be a bare wire hitting some metal while I'm going around right corners and its causing it to stumble. BUT I CAN"T SEE ANYTHING. Is there anyway I can find this short or...........any other suggestions?
:dontknow:
:dontknow:
2010 Yukon Denali
