GONE BUT NOT FORGOTEN
sigpic NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
"For you who believe all you read, I caution you - you are daily being brainwashed for profit by extremely effective psychology with very little regard to factual accuracy. In short, you're at the mercy of the world's greatest bullshit artists with the morals of a stray tomcat." - Smokey Yunick
Depends on what year car. GM started getting cheap in the last years of the 4th gen and started downgrading the WS6/SS suspension.
The 98-99 SS's had 1LE suspension with the exception of the Koni D/A shocks.
http://www.fquick.com/csmith4153 2015 Midnight Silverado Crew Cab 2011 Camaro SS 1999 Camaro SS #4153 1986 Monte Carlo SS 1969 Camaro - 427 Rat
I believe the 1LE cars also had a 21mm rear swaybar and harder durometer bushings. The WS6 SS cars did not get the bushing nor the 21mm rear bar.
Jan 2000 was the cutoff point for the availability of the 1LE suspension option. So all WS6/SS Cars made after that point are equipped with the same springs as the regular V8 Cars, the rest of the Pkg remained the same (bigger wheels/tires 32mm front swaybar different valving Decarbon shocks). BTW the 32mm front bar is same as 1LE.
Craig
Semi Retired Street Racer
Your correct on the rear sway bar. I had to look in my binders that has info on the SS's
The 1LE did come back in 2001 & 2002 as a SLP option on the SS's.
The SLP 1LE cars had a 35mm hollow front bar.
Im guessing bigger diameter sway bar means i need bigger bushings, which ones do i get, does energy sespension make any, i havent bought anything of theirs i didnt like
