vibratation!!!!
  • vibratation!!!!
    car is acting up, has a rotational vibration and a loss of power of sorts... car idles fine, has good oil pressure and the boost climbs. when i rev the car up with the clutch in and in gear the car will move forward... is it a warped flywheel? im at a loss and would like some ideas before i start ripping and taring.
    When do you get the vibration?
    Sold!
    www.fquick.com/lozanoa11
    94 Grand Cherokee (sold)
    95 Accord(for sale)
    99 Outback (snow destroyer)
      whenever i give it gas... i couldnt even stage my car over 2500rpm at the track because it was lurching forward.
        what clutch/master?
        warped flywheel shouldn't cause an vibration while the pedal is down
        if the master is adjustable then you need to make it longer
          its the mcleod street twin with adjustable master, i have adjusted it longer and longer it goes away then a couple days later it comes back, even though its not engaging when i adjust it it still vibrating...
            pump the pedal a few times then slowy let up to about an inch off the floor.(have to do this where its quiet) and hold it there.
            feel/hear for a clicking or the pedal dropping.
            if it is i bet the master is bad. I have 2 brand new masters setting here that I am trying to get a refund for.
            the vibration is something else.
            I guess the clutch could be loose or something. maybe the PP is loosening up and causing the adjustment issue too
              Sounds like the clutch is not disengaging if the car moves foward with the clutch pedal depressed. Maybe the vibration is the due to the clutch.
                also make sure the lines are bled correctly.
                Sold!
                95 Accord(for sale)
                  it was fine for a while and this is a problem that developed after i was giving the car a stress test (spanking on some mustangs) i can make the clutch not engage by adjusting the master but the vibration is always there.
                    check your crank hub, maybe you spun the hub on the crank. How much boost, what blower, Eric L
                      18psi on a F1A Procharger.
                        Is the crank pulley keyed?
                          yep the crank is keyed.
                            I would make sure it didnt spin on the hub. Could it be a fuel issue? Eric L
                              if its a fuel issue theres something major wrong, it has 80lb siemens fuel injectors with duel intank walbro 255's (340 series pumps)
