Originally posted by Plum Nuts
View Post
Help please. car running terrible
I second the burnt plug wire...look over all the wires. Out of curiosity how many miles on the plugs and wires.2011 Ford Raptor SuperCrew
^^dont take advice like this and immediately go out and buy a new Opti. get it scanned and then test the opti to see if its getting a signal. you can test a lot of the ignition parts to make sure that they are in proper working condition.Originally posted by MP81 View PostI think the opti is doing what it does best - failing.
plug wires or EGR. Optis usually fail at high RPMs first rather than low.-Joel
My 95 is OBD1 and it stores codesOriginally posted by my1994z28 View PostIf I remember correctly,his drivetrain is 94 which is obd1..I didnt think that they stored the codes?- Brian Meissen
Well i changed my fuel pump, fuel filter and the rusted fuel line and my car start up right away know, the plug and wire are maybe 4 month old and that was the first thing i checked when it started running bad. It will run great until in warms up then it start running bad again. could this really be the egr?
Im starting to think its a vacuum leak cause the line vacuum line from the valve cover to the throttle body cracked when i pulled it off the throttle body and there oil on the throttle body
