Oil cooler delete
    I also found out the same thing as Eric did through research, the hose from the waterpump to the radiator is not needed. I found rubber caps at Advanced Auto Parts that fit the radiator and the waterpump. Only cost about $5.00 total. Slid them on and held them in place with a hose clamp.
    Originally Posted by 1BADAIR
      awesome! could you get a picture of the caps? Just so i know what im looking for?
        This is all what I just said on the previous page.
        The plugs I got from Murrays Oreilley looks like these but are black adn come in a pack:
          http://www.midatlanticrubber.com/prod_6.htm
          Rubber plugs similar to these, and the ones Brian posted. I believe I needed the 3/4" size.
            What is the original application for those plugs at advanced? Heating and cooling systems? Thanks Eric L
              I don't remember if they had an actual application, or if they were just universal plugs. The ones that i bought were really thick rubber if that's what your getting at. I would have never put them on the car if i thought there was a chance of them blowing through, or getting hot and melting.
                The guy at our local Murrays Oreilleys actually recommended us using those plugs instead of buying the hose that goes between the radiator and the waterpump. At Murrays Oreilley it was over in the section where they have a lot of odds and ends plugs, switches, caps, and pieces.
                  These are the ones i bought from Adavanced Auto Parts. They state right on the back for use when bypassing heater core, or when plugging off waterpump passages. Sorry no pics of them on the car.
                    That's exactly it.
                      Murrays sell a kit of assorted size bypass plugs they slipright on and used a strap to clamp tight.
