OK so i have a problem that has been persisting through a few months. When i try to start my car it takes awhile for the crank to turn the car over and start. Fuel Pressure is at about 40 sum odd lbs. built up right before i start the car. i took the car to the track for a run (14.1 @ 100 mph (: after the car seemed to be running really rough. I took it to the test strip and when i slowly accelerated the car bogged down really bad. and when im in neutral and give it gas the car bogs down and almost stalls. Plus when i slowly accelerate in any gear (manual) i can feel the car jerk (bearly but enough to feel it). This problem happens at any temp and is an off and on problem. Please anyone gimme some help,
I have replaced...
Plugs
wires
opti spark
ignition coil
gas lines get hot from engine but have no holes and are solid
battery connections are good
I have replaced...
Plugs
wires
opti spark
ignition coil
