KYLE !!! Your scaring me !!!
What kind of OPTI did u put in my T A ???????
What is does that mean?
Shit happens!
What happened to Red's car isn't anything I did or made happen it just did.
Don't mean that you have a defective part or that I put junk on you car or any car that I work on.
If your worried about the work I did on your car don't bring it back!
Easy there Kyle!! If I remember right didn't you do something different to Red's Opti, that most likely you didn't do to Tony's!! Therefore his should be just fine!!
92-93 are the same they have the splined shaft that is removable.
It has splines on both ends and used on 92 Vets and then used on 93 F-Bodys.
94-97 is different making my TA and Red's Camaro one-offs
I wish I had a pic of one but if you have it you will know it.
Can you get a pic of it Tom so I can see it?
Tony's opti is run by the Cam Shaft pin unlike 93's that have the shaft to turn the rotter.
The only way Tony is going to have an issue is if he runs an after market Cam and doesn't check the length of the pin to the stock one.
And the only reason I can get parts cheaper than most is because I run THOUSANDS of dollars through the place that I do so I get a discount on parts.
+ I try and keep my businesses local!
I help you, you help me.
I'll go try and find it. I'm pretty sure it came off a 97 car but I could be wrong.
From what I know, 92-93 opti's are the only ones that have the removable shaft because everything from 94 & up is run by the cam shaft pin.
Thanks
No shaft but its a good opti off a 97 LT1. I thought there was a shaft suck on the back of it that could help you. Doesn't do you any good though, does it? By the looks of it, you'd have to replace the timing cover.
1999 Pontiac Trans Am- LS1 - M6 - ITSSLOW - 12.998@109.59 - SOLD
1994 Chevrolet Camaro - 3.4L - M5 - ITSSLWR - 16.558@85.38 2003 Chevrolet Blazer
That won't work for Red's car
For the 93's you have cut the pin short on after market cams because of the timing cover.
Thanks for looking though
I figured all optis were the same and I knew it was off a 97 car. I figured the shaft was just on the back of it. I know what you're talking about though because we did a cam swap on Kolin's 93 Trans Am and I know exactly the 1" shaft you need.
