Spark plugs
  • Spark plugs
    Has anyone used the E3 spark plug in their lt1?If so did you notice any difference in performance?any difference in idle or hp gains?I watched horse power and they tried them in a engine and gained 4 or 7 hp..
    I have heard they work well on bolt-on cars but past that you needs less gap and there is no way to adjust the gapping of those plugs, I'd spend that cash elsewhere.
      I always go AC Delco...
      **** FEAR THIS ! ***
        I always run the factory brand. All my GM products have always got AC Delco. Didn't matter if it was my stock 2.2 Sonoma, stock Trans Am, or my built 355 I had. Same with my Ford's, they always get Motorcraft.
          One word: Iridium.
          Used to own a Firebird.
            Oh yeah, the power gain they showed on TV was probably the gain over a plain old copper core resistor plug, probably over an autolite or something...it's advertisement.
            Kinda like the time they showed the hp gains from using royal purple-the other oil they used was like a conventional wal-mart brand.
              Not that it really matters in my bolt on 6, but i use AC Delco iridiums, a little pricey but my car even idles a little better.
              "Blue Devil"
                I ended up staying with NGK TR55s
                  Unless your spark plugs are fouled in the 1st place then replaced there should not be any HP gains at all.
                    It would make sense that plugs wouldn't make a difference on an LS1 seeing as the coil-per-cylinder supposedly makes spark energy around 200% stronger, but on an LT1 with an opti and long plug wires...
                    I was thinking of going to a TR5IX though.
                      they actually tested the plugs on an ls motor on the show and it did make more power, they also had a little spark testor to show how much better spark they achieve. Like I mentioned though they are not adjustable for gapping and that is the downfall, they probably aren't bad plugs but they are wayy too overpriced and TR-55s have been proven over and over for years.
                        Think the TR5IX's would be a considerable gain over a delco platinum? I think I can get 'em for about $5-6 a piece and I might as well when I have everything out of the way.
                          TR-55s have been the standard for our cars for years, why try and reinvent the wheel? Stick with what works, they are only plugs for petes sake.
