4 bolt mains?
  • 4 bolt mains?
    Everything I have read on the net says that camaro did NOT come with four bolt mains unless they are an LT4. When I had my bottom end off it HAS four bolt mains. is this not the original engine in my 97? Is this a 'vette LT1? Was I high on drugs? This is exactly what the botom end of my engine loks like:
    Here's a sig with my old ride: (Everyone else has a cool sig I had to do something!)
    High on drugs.....
    Or you dont got the original engine. Is thats your engine, in the pic then NO cause that block is aluminum.
      All the Camaro LT1's were 2 bolt mains to my knowledge, and even the LT4 Camaro was also a 2 bolt main. The Corvette however, was a 4 bolt main. I have no idea why but I did some research before I was about to buy an LT4 T/A with a Corvette motor...which I did not buy.
      Used to own a Firebird.
        You arent seeing things, there ARE factory 4-bolt cars. GM used corvette blocks when they ran out of f-body blocks. It is documented to have happened, but I dont think anyone will ever know how many were actually produced like that. You are lucky.
          x2 and you have all the original numbers so that cars worth some bucks.
            Hell yeah! My build date is 12-96. I just ran the block number on www.mortec.com and it said it could possibly be a 4 bolt main. Well something positive has come with this car! Lol!
              yep, they probably will be worth money someday. I was hoping mine had one when i tore it apart but no such luck.
                Somebody got very, very lucky!
                  Was the whole 4 bolt main thing only on '97's?
                    what are the benefits?
                      congrats on being lucky
                        its just stronger. If your under 600 hp, Dont even worry about it.
                          That and I believe they can handle higher RPMs with more stability.
                            no im pretty sure ive heard of it happening in 94, 95, and 96 too. havent heard of any in 93 yet but that doesnt mean they arent out there.
                              I was always told 4 bolt mains were the ones to build up because they are built stronger.
