Hello every one hey I'll be doing a tune up here soon on my Formula which is nearing 114k miles. O what fun on my LT1. Including cap, rotor, Wires, plugs, belt probly. What I would like to know is what would be the best parts to go with? Been looking at MSD Cap, Rotor, and Wires. Are those good? Bad? ugly? I have heard good things but wanted opinions of fellow F-body owners. Also as far as plugs Champion, AC-delco, NGK--< have heard these are cheap pices of crap? Again just want to know what some of my fellow F-body owners use.
Need sugjestions on tune up parts
Originally posted by KuruptWS6spdI'm young, speed matters.....
1996 Firebird Formula
BBK 58mm Throttle body
SLP cold air intake with Trick Flow Elbow
Hooker Long tube headers
3" Flowmaster exhaust
Spohn Panhard bar
3.73 rear gear
Custom tuned by JET DST -
Id hit it up with
MSD cap/rotor/wires
AC-Delco plugs
New belt if needed
Some fuel injector cleaner (SeaFoam)
Change trannyfluid / filter
Diff fluid
Air filter?
Hows the coolant look?
Grease up suspension zerks, UJoint zerks (if you have them)
Hows tailshaft seal?
Suspension bushings still looking good?
Make sure you watch the blinker fluid level and check your muffler bearings for excessive wear.
Funny. but other than that sounds good Air filter already done K&N. Rear diff fuild is going to get changed then 2 because of a leaky ring and pinion seal. Fuel injectors cleaner just put in. Tranny fuild gets changed in a few days hopfuly not easy to do things when u have a broken collar bone sucks. Doing my best to get things done while I have some free time.Originally posted by MattODoomMake sure you watch the blinker fluid level and check your muffler bearings for excessive wear.Originally posted by KuruptWS6spdI'm young, speed matters.....
Spohn Panhard bar
3.73 rear gear
Cool, just dont overlook things.Originally posted by MerlinFunny. but other than that sounds good Air filter already done K&N. Rear diff fuild is going to get changed then 2 because of a leaky ring and pinion seal. Fuel injectors cleaner just put in. Tranny fuild gets changed in a few days hopfuly not easy to do things when u have a broken collar bone sucks. Doing my best to get things done while I have some free time.
There is more to a tuneup then just the engine.
Get the suspension greased, check wheel bearings, brake pads, that kinda stuff.
ya I have lot of time on my hands due to my broken bone cant do much at work there for not given alot of hrs. So I'll work on my car yay. Usaly have no time due to work and school got summer off school. Also luckly for me my brother works grave yard shifts where he works and can help me some during the day.Originally posted by KuruptWS6spdI'm young, speed matters.....
Spohn Panhard bar
3.73 rear gear
