I was wondering if anyone knew the piston ring order. I didn't pay attention when I was taking them out for some reason. They are stock GM LS3 rings.
I know the Oil scraper rings and spring go on the bottom but I don't the order for the top two rings. One is thicker than the other both they both fit in each slot.
the first ring is probably flat.
the second is most likely tapered . you should see a silver line on the face. Thats the part that is actualy sealing .
