to all of you 3800 guys
  • to all of you 3800 guys
    whats your avg oil pressure?
    at idle after just started
    and warmed up at idle
    1996 Base Model
    +2 cylinder mod
    Mine used to be about 60 regardless, a pinch higher when cold.
      wow
      somthing must be wrong with my car
      its at about 60 when first started
      and goes to 30ish when its warm
      in the 200* area
      1996 Base Model
      +2 cylinder mod
        Could just be tired, could also be the oil and filter combo you have. What are you running for oil and a filter? Have you tried changing the oil and seeing if that helps. BTW, 30psi is quite acceptable at idle. On a GENERAL basis, you need roughly 10 pounds of oil pressure per 1000rpms.
          its some conevtional 10w30 castrol
          i heard not to use syn on break in
          and a fram sure grip filter
          1996 Base Model
          +2 cylinder mod
            I run GC 0w30 in the new motor, but ran any general 10w30 in my v6 and had no issues. But that fram filter scares me, some people get lucky, but others, not so much. Youll never see one on any of my vehicles.
              whats wrong with them?
              what should i use opposed to it
              1996 Base Model
              +2 cylinder mod
                They have a tendency to crush themselves.
                Pretty much anything is better than fram oil filters. Mobile 1, pureolater premium plus, and napa gold are the best. IIRC k&n isnt to bad either.
                  mine also seems to hold a pretty constant 55-65 psi no matter what and a little more cold.
                    yeah theres no reason for mine to go down i dont think
                    i have a brand new oil pump and all mains and rod bearings are new
                    sould i try running 10w40?
                    1996 Base Model
                    +2 cylinder mod
                      I dont see why. Like I said, 30 is fine at idle, what is it while crusing and getting on the gas?
                        just crusing at say 1800 rpm its only like 40psi getting on it itll get to 65
                        but i looked somewhere online and it said it should be at 60 at 2000 rpm
                        1996 Base Model
                        +2 cylinder mod
                          It might just be a bad oil pressure switch. Hook a manual gauge up to it if you can get your hands on one and see if it reads the same.
                          (Insert future F-body here)
                            when i had mine it idled just under the half way mark and really never moved when i reved it up i used 10w40 with a K&N filter same as i do now with my Z
                              Thicker oil is not the answer, stay 10-30 and change the filter to a napa gold or other. NO FRAMS!
