LT1 intake manifold q?
  • LT1 intake manifold q?
    Can i remove the intake manifold on my lt1 without dropping the cradle?
    i haven't really looked at it enough to determine this and i honestly don't know that much about LT1's
    and also, can i remove the air pumpers on my manifolds without it affecting anything? besides gas mileage.
    1996 Trans Am. 355 LT4 + some go fast mods.
    www.360icons.com
    _ Do you have what it takes to become an icon?
    _
    <Atmosphere> Call of duty mw2 summer 10' Ladder
    Gamebattles.com
    Perlsh
    if by cradle you mean k member, then no you dont need to drop it im pretty sure. we did a cam swap and heads and everything on kolin's lt1 ta without touching the k member. but i might be mis understanding you, idk.
      ohhh yeah definately can take it out the top if thats what you mean, there is some stuff to be removed first though
        Yeah, A.I.R. should come off pretty easily, though you'll have to weld the holes where they connected to the manifolds shut.
          Yes and Yes
            Or get some pipe plugs from the hardware store for a few bucks. Just keep in mind you will throw a code.
            1997 Trans Am
            www.fquick.com/transampimp
              Yea no need to drop the cable make sure you have quick disconnects for the fuel lines..Its really easy to do
                cool i appreciate all the help guys.
                ill be taking off the top end Monday most likely, just for cleaning & gasket changes and try to sort out any problems there may have been.
                and if all goes well im going to take the heads out to Allard Engineering and see what jim wants to do with them
                www.360icons.com
                _
                Gamebattles.com
                Perlsh
                  You doin this at your place JC?
                    When you put it back together, pay special attention to the rear of the intake. Use a lot of sealant and make sure the surfaces are really really clean.
