Best place for these parts
  • Best place for these parts
    I am wondering where the best place to find some parts is.
    I need the egr blockoffs for header install and matching gaskets
    i also need header gaskets and bolts.
    West Michigan Firebird Club
    www.wmfirebird.com
    ebay is a good place
      CS3 Automotive/ Creight is where I would check first
        Check with Creight first for sure, if he doesn't I know ebay does.
          Ebay for the EGR plates.
          Keep it local and Automasters can get good gaskets for the headers and collectors, see John, he'll just look up what I have and give it to ya
          The Alum. dead soft gaskets are the best IMO for the collectors
          The EGR, just use Ultra Black RTV for a gasket
            also need 02 extensions if creight sees this
            www.wmfirebird.com
              I heard the factory GM gaskets and bolts were one of the best to use.
                ive done that with about 4 header swaps now.... use loctite if need be
                honestly i got some header bolts when i bought my new 1 7/8in headers for my camaro the bolts were garbage and almost stripped out one of my threads on the head.
                The LS1 or Go Home Crew
                ASE master certified
                  Thanks for the input guys.
                  www.wmfirebird.com
                    next questionis do i need to replace my plug wires. i just put on brand new 8.5 msd super conductor wires last summer.
                    www.wmfirebird.com
                      Not unless there bad? I guess it would depend on the boot style too, but even then I would imagine it wouldnt be an issue.
                        Na, those are good yet.
                          DON'T USE A BLOCK OFF DUDE! I had one on my shit...Blew the whole thing right off...if you're not using it, cut it off now and weld the hole. Cost me $300 just to get the header taken off and weld the hole shut.
                          98 Trans Am WS.6
                          Cam
                          Heads
                          Intake
                          Full exhaust
                          More mods to come
                            Or just buy long tubes.
                              He does have long tubes, that's why he is asking.
                              As far as block off plates, I have been running them on my car for years with no problem and so have millions of LT-1 peeps.
