mine is somehow surviving... thankgod for wheelspin
What is wrong with the ten-bolt?
Just to clarify, the 10 bolts in 3rd and 4th gens suck.Originally posted by JoeliusZ28 View PostThey are junk but i dont think they get enough credit at the same time. Jons is still surviving and thats enough said. If there is one thing GM sucked at it was rear axles. Theyre a PITA to work on compared to everything else and bottom of the barrel on strength. That even goes for the 12 bolt.
1st and 2nd gen 10 bolts are just fine, and were routinely put in 400 tq cars.
I blame it all on GM commonizing everything to a Chevy based platform in 82...it was all downhill from there...
Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
I was more or less saying that chevy rear ends in general just arent as easy to setup as a Dana/mopar or ford.Originally posted by 81DaytonaPaceCar View PostJust to clarify, the 10 bolts in 3rd and 4th gens suck.
We did a gear change in my cousins coronet in about an hour and it was setup perfect.... you could never do it on a chevy.-Joel
...Originally posted by JoeliusZ28 View PostI was more or less saying that chevy rear ends in general just arent as easy to setup as a Dana/mopar or ford.
The only people having trouble with the 10 bolt are the drag racers with sticky tires.
Road racers pump out high hp levels and still use the 10 bolt. The ten bolt is very efficient compared to larger differentials. The ford 9" is beefy, but robs alot of power.
9 times out of 10, the 10bolt brakes at the starting line of a drag strip.. Which is why i dont mind my 2.0 60' times..
what? you pull the entire pig out from the front on those axles which means you can swap that entire peice out and not have to mess with gear lash. the chevy doesnt follow that design, you have to fiddle around with shims or just hope the one you had was close enough. The ford axle pinion gear also meets the ring gear at a different angle which is explains a lot of its strength advantage (but also why it robs some power)Originally posted by 81DaytonaPaceCar View Post...
not even sure what this is from, but this is the type of design on the pig i am referring to:
With an axle like that, people can have different gearsets for "the weekend" at the track because its not a big deal to change out and have some fun.Last edited by JoeliusZ28; September 11th, 2008, 10:02 AM.-Joel
