I just got my new passanger side mirror assembley in the mail and need to install it on my camaro. Does the old mirror just pull off and the new one just go on? Cauz thats what it looks like. I just dont wanna rip the mirror off my car and be screwed over.
Help!!!!!
Good god no you have to take your inside panel off of the door i mean the whole thing you should see where it bolts to the door remove those bolts and any wiring reconnect the wiring bolt it back to the door put panel back on done, but first i want you to take a good pic of the mirror inside the door and outside si i know exactly how to help you
Outside Rearview Mirror Replacement
Removal Procedure
Remove the mirror bezel screw. (2) Remove the mirror bezel (3). Remove the remote handle from the bezel, if equipped. Remove the door trim panel. Refer to Door Trim Panel Replacement . Disconnect the electrical connector, if equipped.5.1. Pull the rosebud clip on the electrical connector from the mirror.
5.2. Disconnect the electrical connector.
Remove the outside rearview mirror nuts (1) from the mirror assembly (2).- Remove the outside rearview mirror (2).
Install the outside rearview mirror. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the outside rearview mirror nuts (1) to the mirror assembly (2). Tighten
Tighten the outside rearview mirror nuts (1) to 12 N·m (106 lb in).
Connect the electrical connector, if equipped.3.1. Connect the electrical connectors together.Install the door trim panel from door. Refer to Door Trim Panel Replacement . Install the remote handle to the bezel, if equipped.
3.2. Press the rosebud clip onto the electrical connector.
Install the rearview mirror bezel (2). Important: Ensure that the retainer guides on back of the bezel are aligned with the holes in the applique.- Install the rearview mirror bezel screw. Tighten
or you can just follow this diagramOriginally posted by TSTONE View PostOutside Rearview Mirror Replacement
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=365388&pubCellSyskey=11215&pu bObjSyskey=365388&from=sm&cellId=11215#ss1-365388">Removal Procedure
<LI type=1>Remove the mirror bezel screw. (2) <LI type=1>Remove the mirror bezel (3). <LI type=1>Remove the remote handle from the bezel, if equipped. <LI type=1>Remove the door trim panel. Refer to Door Trim Panel Replacement . <LI type=1>Disconnect the electrical connector, if equipped.5.1. Pull the rosebud clip on the electrical connector from the mirror.
<LI type=1>Remove the outside rearview mirror nuts (1) from the mirror assembly (2).- Remove the outside rearview mirror (2).
<LI type=1>Install the outside rearview mirror. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
<LI type=1>Install the outside rearview mirror nuts (1) to the mirror assembly (2). Tighten
<LI type=1>Connect the electrical connector, if equipped.3.1. Connect the electrical connectors together.<LI type=1>Install the door trim panel from door. Refer to Door Trim Panel Replacement . <LI type=1>Install the remote handle to the bezel, if equipped.
<LI type=1>Install the rearview mirror bezel (2). Important: Ensure that the retainer guides on back of the bezel are aligned with the holes in the applique.- Install the rearview mirror bezel screw. Tighten
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
