Is it cammed? Stall'd? Normal? F-ed up?
    you know what you can do, just remember the rpm it feels like its slow up until the rpm where you really want it, then get a stall converter of that size and you wont have to worry about the lower rpms anymore.
    ~Phil
      ok well i think i can elminate a stall...
      I held the brakes and gave it gas, the tires were spinning at 2.5K or so rpms...
      doesn't that eliminate say a 3000 stall?
      '96 Camaro RS - project
      '97 Silverado Z71 - DD
      '89 Suzuki GSXF 750
        also the trans received a rebuild in may...i wouldn't think that would be going? I hope not
        if it is...T56
        '89 Suzuki GSXF 750
          yeah the tires can spin at any rpm, but if you want to check your stall speed come to a complete stop, keep the brakes in all the way possible and then slowly load up the gas and raise your rpms.. whereever it stops climbing in the rpms is your stall.. stock on my car is 1800 yours should be somewhere around there.
          ~Phil
            yep that's what i did...
            the tires are brand new so they didnt' squeal so i had to listen carefully over the exhaust but i think they spun somewhere near 2,000...so yea
            '89 Suzuki GSXF 750
