2010 6-speed manual issues
  • 2010 6-speed manual issues
    http://www.autoblog.com/2009/07/13/b...ures-reported/
    Time to drive like a granny until the issue is found with the trans. vendor.
    Yep, just saw that...GM just can't catch a break...
      at least this one doesn't sound like it's their fault
        Won't matter...a few more fence-sitters that may have been considering their first GM product in a while just got chased away...
          If so they were never serious to begin with - the article makes it sound like this will likely be a small segment recall to retro fit a limited number of vehicles that are already in the channel. This will have little to no effect on the masses that already have vehicles on order.
            Not to mention most people are still babying their new engines anyway... Fred hasn't had any issues with his.
              I'm at work, what's the problem?
                People who do hard launches or use launch control blow up stuff.
                Sporadic reports have begun popping up in the Camaro5 forums about issues with V8-powered SS models equipped with the manual transmission. It seems that doing a hard launch or using the launch control system occasionally results in a broken output shaft, a serious failure that will most likely leave the car immobile and in need of repair. We spoke with General Motors spokesman Adam Dennison about the problem and, as this is being written, a factory hold has been put on deliveries of manual transmission V8 Camaros while Chevrolet engineering teams investigate the problem.
                Based on the reports, the transmission issues may not be related to the launch control system as the failures seem to happen whether or not launch control is engaged. The Camaro SS uses the Tremec 6060 six-speed gearbox – the same transmission fitted to the Dodge Viper, Mustang GT500, Corvette Z06 and other performance cars – so this is likely a manufacturing issue with a batch of gearboxes.
                Dennison told Autoblog that an engineering meeting is being held this evening to identify the cause and establish a timing for the fix – and a recall seems likely. In the meantime, if you have a manual model Camaro SS, you might want to go easy on the launches for now – and if you have one ordered, you'll have to wait a bit longer. Thanks to Bailey and Derrick for the tips!
                  *Cough* Alfa Race *Cough*
                    Alfa race? What's that?
                        Just leave the launch control off
                          5th gen fail..... I hope it doesn't become synonymous with LT-fail....
                          "ANY car can be an SS but ONLY a Camaro can be a Z28!" Scott S.
                          "Owning a 9 second import is like coming out of the closet. At first you surprise everyone, but in the end you're still gay!"
                            I doubt a small batch of issues is going to be anywhere compared to the Opti-fail.
                              according to the article it doesnt sound like that makes a difference
