y pipe and tranny coolers installed
    its not on cuz it doesnt fit gary, going from a 153 tooth flywheel to a 168 doesn;t work with that cover
      It's bigger for the bigger flywheel right?
        they must make a bigger one but i don't plan on buying one ill just re form the one if i have to but idk if it will fit
          Thats no excuse, get a different one.
            find me one....
              Reform????????????????? Nah,find u a new one.Better off that way.
              **** FEAR THIS ! ***
                  well it only barely hits it so i if i can get it out a 1/4 inch im good to go
                    Originally posted by Orange Terror View Post
                    Nice work Sean. Everything looks good. I'm curious if the tranny coolers being there will affect the cooling abilities of the radiator. Not only because they will have hot air coming off them but also they may disrupt the airflow some. I like the idea, I just hope it works alright. If it stays cool then I guess it worked well!!!
                    Great minds think alike. I was thinking it was gonna eff with the airflow too, but who knows, I might work...I would just be REALLY concerned withg taking a rock on the trany coolers....those tubes are really thin aluminum.
                      Now your making the youngster worried !!!
                        well considering a lot of air comes in through the vents i figure it should be fine, however i thought about it and if it so happens to get hot which i don;t think it will with the new radiator and everything else, i will just move one so it creates more airflow but the fins on these tranny coolers are spaced fairly far apart so it should let alot of air flow through as well
                          They look pretty sharp like that. I did mine in front of the radiator cuz it was easier to mount.
                          Holley 650cfm Double Pumper
                          Edelbrock Performer-Plus Cam
                            i was gonna do that but then i decided i liked this better cuz either way if its gonna get hit by a rock its gonna get hit then plus a rock will only be able to hit these if it has some weird ass bounce to it
