I had that "back-firing" problem on my '94 LT1 @ WOT. Found a leak in one vac line(near the TB). It'd be a good idea to check for that yourself.
1996 Formula
u can add a vacuum can for added vacuum. I know Justyn has one on his 72 that he has to install yet.
But I agree, I would check for a vacuum leak.
I know some people who have put some nasty cams in 4th gens, and they never had a problem.
Cant tell much in the vid. Guess you will have to pick me up and take me for a ride LOL!!sigpic
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
Hey you never picked me up last summer!
The owner told me one of the headers has a leak and he gave me new gaskets for both sides. So those need to be changed out. I'll look for some vacuum leaks. How would I add more vacuum if I wanted too?
In my exhaust thread Brian said something about brake boosters and stuff. Would any of these be what I want?
http://www.jegs.com/webapp/wcs/store...atchallpartial
Thanks!
Brake boosters work off the vacuum created by your engine, including the stock one located right behind your master cylinder. Check for the leaks first. Depending on the cam profile, you may need to get a vac canister. That canister will store vacuum & allow you to use your power-steering & power brakes when the engine doesn't produce enough itself.Originally posted by SoulTerror View PostHey you never picked me up last summer!
Thanks!
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- Winston Salem, NC
Only time I have is brakes is like below 5mph when the engine is barely idling. Haven't' had any power steering issues.Originally posted by 2EVUL4U View PostBrake boosters work off the vacuum created by your engine, including the stock one located right behind your master cylinder. Check for the leaks first. Depending on the cam profile, you may need to get a vac canister. That canister will store vacuum & allow you to use your power-steering & power brakes when the engine doesn't produce enough itself.
congratz Mark..
That sounds like crap, I know its on the phone but WOW..
While watching the vids though when you revved the car up at first the left side looked to moved ALOT, maybe the pipe is not seated in the muffler all the way.. I would check that out as well.. good luck though, I bet even though it has issues your geeked beyond belief..Last edited by Gottork; March 10th, 2010, 08:59 AM.99 Buick Regal GS- New DD
SOLD-1967 Buick Skylark
This is what Brian was referring to http://www.jegs.com/i/JEGS/555/63010/10002/-1Originally posted by SoulTerror View PostHey you never picked me up last summer!
Thanks!Western Michigan Camaro Club ~ President
yessir - that's what I was referring to.Originally posted by WMCC Gary View PostThis is what Brian was referring to http://www.jegs.com/i/JEGS/555/63010/10002/-1- Brian Meissen
That, or what I said - which is actually a belt driven vacuum device that creates vacuum.Originally posted by WMCC Gary View PostThis is what Brian was referring to http://www.jegs.com/i/JEGS/555/63010/10002/-1Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
congrats mister! lol, it looks like the previous owner did all that he could to make every lil piece in there as camo as possible... ..or am i just seeing things?
You shouldnt be seeing anything - it's camouflage!!! ShhhhOriginally posted by MORNINGSTAR2101 View Postcongrats mister! lol, it looks like the previous owner did all that he could to make every lil piece in there as camo as possible... ..or am i just seeing things?Gone but not forgotten: 1986 Chevrolet Camaro IROC-Z
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- Winston Salem, NC
It's just the head liner shesh. The trim on the doors around the stereo is more like a granite look. Have to see it in person or something. I like the trim so it'll be staying. Breaks up the black on the inside and it's different.
