Anyone use the KYB AGX?
    Sooooooooo I just bought the konis.... lol
    99 Trans am
    - SLP Air Take (LID)
    - Ported and Polished Throttle Body
    - LS6 Intake Manifold
    - 1 3/4 Long Tube Headers
    - 3" Y-Pipe
    - 3" Magnaflow Catback
    - Lower Control Arms
    Soon
    - Heads/Cam
    - 3600 or 4000 Stall
    - 3.73 Gears
      I guess last question is, beside the four shocks and the two front mounts, is there anything else I'm going to need?
      99 Trans am
      - 3" Y-Pipe
      Soon
      - Heads/Cam
      - 3.73 Gears
        Just the front top mounts and the little insulator piece if you didn't get it, K6573. I would take a look at all the bushings and ball joints while you are in there to see if they need replacement. If not then those will be all the parts you would need. Definitely throw some grease in the pocket of the front shock upper mount, between the frame and the bracket. Helps keep rust away.
