OK, here's your dumb question of the night....just looking to sense check this with you all...
I've had this "clunk" in the suspension ever since I lowered it last year. Front suspension clunks over larger bumps. Feels like it's right below my feet and it's tough to tell what side it's on.
Tonight, while poking around under the car for the millionth time trying to find the source of this noise, I noticed that on the outer ends of the sway bar, it appears the bar may be contacting some brackets welded to the unibody. These thick gauge brackets hold a round metal bar support brace.
My question is - I should have shorter-than-stock endlinks, being that I dropped the car a solid 1.5" or so, right? I am running OE length ones (O'Reilly house brand). I think it's throwing off the geometry of the sway bar, and when it twists enough, it contacts these thick solid steel brackets. I should probably cut a good 3/4"-1" out of the spacer to bring the end of the sway bar closer to the lower control arm, right?
Most likely a stupid question - I think I need to shorten them - but I want to ask before I yank it apart again and waste time when I find out that's not the issue.
Not lowered, brand new everything (even control arms) and it still pops when it articulates hard. I'll be dropping the bar and checking for cracks soon.
