Tire sizes help!
  • Tire sizes help!
    I have 17x8 and 17x10 wheels. What is the best tire sizes for these wheels? Thanks
    Air Force/Afghanistan veteran
    1987 Iroc camaro Supercharged 5.3
    2012 Toyota tacoma
    Best size for what
      26" tall?
      255/45/17 and 295/40/17
        Just the width. So 255 and 295. They are going on an 87 iroc
        2012 Toyota tacoma
          you can fit a 295 on a 10" rim? I have 17 x 10.5's all the way around on my 95 and I was looking for a bigger and wider tire, the guy before me put 245/45/17 on them and they look to short and way to narow, I wasnt sure what size to put on. I was thinking 275's could i swing the 275's up front and 295's in the rear?
            Tire sizes help!
            IMO 245/285 is the biggest sizes that are actually worth it on that size wheel. Any bigger than that and it's just a bit oversized. I would make the decision more based on availability and price.
              295 is the biggest you can fit on a 9" rim, should be right at home on a 10"
              Shop brands, 285/295 can get expensive
                Most Brand suggest a 9.5" wheel for a 285 tire.
                I have Nitto 255 45 17s(8" wide) and 285 40 17s(9.5 wide) on my chevelle. Overall tire diameter is the same just an inch wider in back.
                  ^ correct. But it can fit, albeit pushing the limit.
                    Tirerack.com has some good information and also a lot of specifications. You can also look at tire manufacturers websites for that information. A couple examples:
                    http://www.yokohamatire.com/tires_10...m_wheel_width/ <--max rim size
                    http://www.tirerack.com/tires/tirete...jsp?techid=198 <--tire sizes vs rim width explained
                    http://www.tirerack.com/tires/tirete...e.jsp?techid=7 <--tire sizes explained
                    -Homer Simpson
