lowering questions.
  • lowering questions.
    Thinkin of lowering my car...my goal is a slightly lower stance with no rubbing and a stiffer spring wood be nice for less nose lift and dive.. any tips or pics ? cut spring, hh mod, new springs, etc. my car is stock with 275-45-17s with 17 x 9.5 c6 replicas..
    I would just do the heater hose mod to level out the stance.
      +1 on the heater hose to start and if it isn't enough then move to springs.
        just checked tires they are actually 275-40-17 not 45...anyway..if i do the hh mod will i still need the adjustable panhard bar ?
          Nope. I'm running the LT1 Eibach Pro Kit on my 98 Camaro. A little low in the front because of the iron 6.0 but didn't need the adjustable panhard, I put one on because I'm picky and wanted it dead center
            I have cut front springs(one coil) and love them.
            I did heater hose mod on the rear..hate it. This spring I will be cutting half a coil and putting the rubber isolators back in.
            In the past I had the LT1 Pro Kit..loved it but now that I have cut springs I think a reasonable cutting(no heat) is perfect for most people.
              y did u hate the hh mod ?
                It seems harsh. That rubber piece gives you some cushion from the springs hitting the body.
                Cutting the spring just seems like the right thing to do, as half assed as it sounds.
                  SLAM IT! Low is the way to go.
                    I got 1.5" lowering springs and some better shocks and love the ride. Still have ground clearance too
                    Go BIG or go HOME!
                      Legit lowering springs and upgraded struts/shocks to match, FTW.
                        just get the correct stuff the first time
                          This is very true ! Took me a long time to figure it out lol
                          Go BIG or go HOME!
                            Yup, spend the money up front once, instead of spending more money to do it again.
