WANTED: need axle redrill to drifferent lug pattern
i may be very wrong but wouldnt you need new axle shafts with the proper pattern?
nevermind i understand now. its a travel but theres an axle shop on groesbeck and 16ish that may be worth checking out. heard many good things about them
be able to make the holes perfectly and then drill myself
NO.
Find a shop, or have DTS send it out to a shop, so you can have it done right. Nothing worse than compromising you or your car over by finding a cheap way to get 10 new holes.
Didn't know they were that close. I figured with shipping costs back and forth you wouldn't be far off from a new set of axles
Glad you're doing it right. The rotors can be drilled with that template, but on an axle flange running lug centric wheels it is imperative that it is spot on.
