Who has installed relocation brackets... bit of a problem
Here it is upside down so that you can see how it wouldn't line up even with the shock bracket out of the way.
And here's the part in the way or whatever. I just emailed founders they said they've never seen one like this before. I can't be the only person to ever mod a v6 And I thought our rear ends were the same.
well there isn't exactly much room to position a camera around in there. Founder's called me and said it was indeed the e-brake bracket and that I would have to cut it out, as this bracket should go around both parts from the outside (as obviously the LCA is in middle so you can't put it there.
I think I'm just going to install my LCA's and see how i like them. If anyone on here has the tools to help cut those parts off I'll take you up on your offer. Then I can install the brackets later on as it was pretty easy to get in there. I still want to get my LCAs on for now though.
On mine, the bracket in red was not there, and the two green faces met up with each other. The re-lo bracket goes on the outside of the lca bracket. 00firebird issue.jpg
Man up and just bend them out with pliers.... You don't "need" to cut them off. It would just look better that way if someone were to crawl under the car and look.
