Who has installed relocation brackets... bit of a problem
    Mine did not have those, it is a V6 car, but older.
    1996 Base Model
    +2 cylinder mod
      we normally just cut the 1 side off
        Originally posted by farmington View Post
        If you're free during the day, you're welcome to come over and use what I have. I'm near 13 and drake
        Wouldn't want to mess up your tools but if you want to do it I'll bring some beers.
        Also it looks like the bracket is now 1/16th or so too small to fit my LCA (the poly side is fine and mounted, the roto-end on the rear end side is causing the trouble). so much for easy.
        ~Phil
          Hmm.. ls/lt brackets gotta be different.. mine went right on.
            Mine is a 99 LS car and it had those brackets.
              put a little 50 grit sandpaper on my buffer and turned it on each end for about 5 seconds, was enough to get it in there and keep it tight fitting. LCAs will finally go in today
              Well, at least now I can compare having lca only and lca + reloc. brackets to see where the difference comes from.
              ~Phil
                yeah when i put them on i was also putting new shocks and springs, theres no way i could have noticed the difference.
                  I bent one side out of the way on mine
