I have a full length UMI adjustable, I don't get any wheel hop. It just spins tires before it transfers any weight, brand new Hoosier drag radials made no difference. Gonna try taking off relocation brackets and moving torque arm down one set of holes from top. Might play with tire pressure also have always run 18 psi might try 20.
Best torque arm for the money?
Car is auto trans 3600 stall. UMI K member and front and rear control arms. UMI full length TA with relocation bracket. Strange single adjustable shock in rear and QA1 singles up front with 300# springs I believe. Also have lower control arm relocation brackets, car not lowered rear control arms are at 2 deg with the rear lower. Pinion angle 1.5. At my old power level I ran the rear shocks at 7 or 8 with 10 being the stiffest. New set up I need a huge burnout and rear shocks at 1 to hook.
I always just leave from idle foot braking seems to make it worse. Car is 3700#sigpicJust a slow 400 plus RWHP LT1.....428/370 NA
Jim,Originally posted by FASHOOTER View PostCar is auto trans 3600 stall. UMI K member and front and rear control arms. UMI full length TA with relocation bracket. Strange single adjustable shock in rear and QA1 singles up front with 300# springs I believe. Also have lower control arm relocation brackets, car not lowered rear control arms are at 2 deg with the rear lower. Pinion angle 1.5. At my old power level I ran the rear shocks at 7 or 8 with 10 being the stiffest. New set up I need a huge burnout and rear shocks at 1 to hook.
If it's spinning before it transfers - move the torque arm down. It'll ease the hit on the tires and allow the suspension to work. This is what I ended up having to do.
It's going to be a process of finding out what the car likes.
Jeremy2000 Formula
fixed slow junk
I had front of TA in the stock location before I moved it up, guess I will bring it down between the 2 settings. Think I should ditch the relocation brackets? I have them in highest hole I have never tried them all the way down.sigpicJust a slow 400 plus RWHP LT1.....428/370 NA
One thing at a time. The lowers are easy to do at the track when your not a dumb a$$ and try to do it without jacking up both sides of the car!Originally posted by FASHOOTER View PostI had front of TA in the stock location before I moved it up, guess I will bring it down between the 2 settings. Think I should ditch the relocation brackets? I have them in highest hole I have never tried them all the way down.
Edit - Larry beat me to it.Last edited by Nocooler; June 15th, 2012, 09:42 PM.2000 Formula
fixed slow junk
Larry and Jeremy are very knowledgable on this subject and have given good advice, I would keep the LCA relocation brackets as you may need them down the road anyways.Doing less with more
Did it hook at the stock setting? Depending on how hard the convertor hits you might need to go lower than stock to make it work. It just depends what the car wants.Originally posted by FASHOOTER View PostI will drop TA one notch.....and wait for cooler weather2000 Formula
fixed slow junk
I know a little - no where near the experience Larry has.Originally posted by DETROITMUSCLE View PostLarry and Jeremy are very knowledgable on this subject and have given good advice, I would keep the LCA relocation brackets as you may need them down the road anyways.2000 Formula
fixed slow junk
