LCA Relocation
  • #31
    they shouldnt spin
    mine worked best at 20-22. i daily drive them at 22
    I got mine to hook the best at 16, any higher and my 60's dropped off. I marked the rim and tire with a window dial in marker, made a pass and it was over an inch moved. Within 3 passes it wound up about 45* off.
    1996 Base Model
    +2 cylinder mod
    • #32
      I think a torque arm is next on my list followed by 3.73 gears and a converter
      1996 Base Model
      +2 cylinder mod
      • #33
        torque arm REALLY helps at stabilizing things / preventing wheel hop. Even if you dont gain traction you'll at least gain a lot of confidence that you wont have pieces of driveline falling out from under the car.
        • #34
          I hope so.
          I really want to try to get those 60' times lower.
          1996 Base Model
          +2 cylinder mod
          • #35
            TA is the most important thing to have for achieving that goal IMO
            • #36
              Real tires, converter, and TQ arm in that order.
              I went 1.68 pretty easily with BONE stock suspension, 275/50/15 ET Street Radials, and 325hp. No doubt I could have gotten it into the high 1.5's with more seat time and a few minor changes.
              • #37
                I couldn't agree more the tires and converter should get you into the 1.6s no problem unless you suspension is terribly worn get a real tire on the car not those shittos if I remember right you have a 2500 converter?
                • #38
                  Everything is newer, other then the front springs/shocks.
                  The converter I have only flashes about 2100.
                  1996 Base Model
                  +2 cylinder mod
                  • #39
                    The car needs a lot more converter than that if you want it to 60'.
                    This is a bolt on LT1 right?
                    • #40
                      It's got a cam and bolt ons.
                      1996 Base Model
                      +2 cylinder mod
                      • #41
                        seems pretty tight for a cammed car to be honest does it spin the way its setup now? How are you launching it? I agree with Larry I make a lot more power and can easily get away with running more pressure I run 20 in mine, heavier cars like more pressure typically.
                        • #42
                          3500+ converter and ET Street radials and it will be going low 1.6's easily.
                          • #43
                            I launch it off the brake. Just hold the brake enough for it to not creep forward.
                            It did not spin at all last time, that was with a decent burnout to heat the nittos and them at 16 psi
                            1996 Base Model
                            +2 cylinder mod
                            • #44
                              I agree you need more converter.
                              • #45
                                A 3600 stall is on my todo list.
                                May not happen till the winter though
                                1996 Base Model
                                +2 cylinder mod
