The common and factory 17" size is 275/40R17, not 275/45R17.
Unfortunatly they aren't many options for a taller tire while staying with a wide tire on a 17" wheel. I had the same problem with my chevelle, I sacrificed tire height for tire width. I wanted a 26.5-27" tall tire but I ended up with 285/40R17s.
275/40R17s are 25.7"
285/40R17s are 25.9" Not much taller plus most tires manufactors would want you to use a 9.5 wheel.
If you sacrificed width you could do a 255/50R17 which is 27.1" tall.
As far as I know it doesn't have lowering springs. I want it to get taller because the exhaust hangs so low. It's fine but if I hit a good bump she scrapes.
A 275/45/17 is a 26" tire.
I plan on eventually running MT ET street. They make some that are 31" on a 15" rim. I know I'd have to change rims to run those tires anyways.
Originally posted by Yoshi94
lol you will not fit a 31 in a stock wheel tub.. your best bet is to either change your exhaust or run a 28 inch tall tire.. anything more and u will have to do lots of clearancing
Who told you this?
A 275/40R17 is NOT a 26" in diameter. It is 26.74"
I think you should get an exhaust that fits better. Installing taller tires is more of a band-aid fix for a different problem(shitty fitting exhaust). Not all cars can get away with a 28" tall tire. Front tires could look silly et
c
TJ, just fix your exhaust. That is definitely not normal to have it hang that low. Trying to fit a 28" tall tire is not plug and play either, it's gonna be just as much if not more work than fixing the exhaust.
Who told you this?
c
