Picking new wheels for the IROC
  • James, you've always had one of the nicest looking 3rd gens around and it keeps getting better! I would have to agree your last wheels looked great and were more flashy, these new ones are a bit more subtle looking at first glance. But I like that, I've always been a less is more and let the rest do the talking. Great Job! and the mini tubs are sweet!
    1998 Camaro SS Bullseye Turbo
    • Awesome. That is all.
      • damn! that looks good
        - - 5.3/4L80e/T7875 - -
        - Huron Speed Turbo Kit -
        1998 Formula
        • Here is my solution to the lower control arms. Since I have installed them I have beat on them pretty hard and they are solid. I ended up only painting them for now so I can keep a better eye on the welds. After a season or so I'll probably send them off to get powdercoated.
          This is how much clearance is needed for the tires.
          This shows the DOM tubing that I used to sister up to the original tubing. Also I tacked on square tubing on the opposite side to hold the arm from warping too bad when I went to weld it up.
          After I fully welded the DOM tubing onto the side and removed the bracing.
          Weld bead close up. I ended up taking the arms into work to use one of our 440V migs because I was afraid my 110V unit at home just would have the power.
          I plated and boxed the ends of the tubing in for added strength and to make it look a little cleaner.
          Fully welded ready for paint!
          Painted and assembled
          Room to spare...maybe I'll run a 345 series in the future and ditch these little 335's.
          See how the axle side mount is partly inside the wheel.
          • I was wondering how u fab this up today. Looks great!
            • Those are some purdy beads! A 110 might have done it if you preheated the metal a bit, but that's just silly. My next big purchase is a tig/stick/plasma cutter AC/DC unit
              • i want a set those are really nice
                00 Tahoe Z71........Stock
                • That looks involved. How do the R888's handle? Is your rear spring/shock setup strong enough control the extra mass?
                  Burnout vid?!
                  88' Trans Am 350 TPI
                  • Originally posted by scholtmj View Post
                    Burnout vid?!
                    It was involved..lol. The R888's are awesome. They do make a bit of noise at highway speed though. I think I will need new adjustable shocks for the rear...I'm pretty certain the springs are okay.
                    • Looks great James. Defiantly an innovative approach to it!
                      Just wondering when you just didn't go with a double rod ended arm with offset spacers? From the pictures it looks like an offset LCA would have given you the room you needed.
                        Thanks..2 reasons as to why I went this route. 1) I didn't want a double rod end arm due to the noise factor (street car) and 2) It looked like if I did use the double offset rod end it would have put the arm 1/8 to 3/16 away from the tire. So any sidewall flex from hard cornering (into the grocery store parking lot) would have rubbed the tire.
                        • You are the man!
                          • Originally posted by WMCCjames View Post
                            So this is your grocery getter? I love it.
                            • Looks great. Would plating the inboard side of the tube have helped at all?
                              Used to own a Firebird.
                              • There's only one word that describes the work you've done...
                                And that's...
                                Titties. Pure titties. Great job, James! Just when I think your car couldn't be more of the ultimate definition of a 3rd generation Camaro in it's perfect form, you do more things to just blow it away... I say it again.... Titties.
