Good Alignment Shop (For Fully Adjustable Suspension)?
  • Good Alignment Shop (For Fully Adjustable Suspension)?
    Does anyone have a really good alignment shop that would be capable of working with my fully adjustable suspension? It seems like all the laser alignment shops in the area don't have a clue how to do it with fully adjustable aftermarket a-arms and/or slotted k-member holes. The computer tells them what bolts to change and that's it.
    As an alternative, I've also been thinking about picking up an alignment tool from Eastwood to do it myself. I've actually got three cars on hand that need an alignment, so paying for all of those at a shop would come within $100 of grabbing the tool and doing it on my own.
    Any advice would be great. Thanks!
    If you do find a good alignment shop they should not have a problem aligning your car. The reason they don't know how to adjust your car is because most of the modern day cars don't have many adjustments that you can do. Most of your alignment shops will only check you caster and camber and they will usually only set your toe and nothing else.
    Those alignment tools from eastwood are good, but they are not perfect.
    You really need to have both front tires on a roller pad (turn plate) to unload the front suspension and to be able to turn the front tires left and right to check the caster setting correctly.
    If you do buy the tool you can rough in your alignment and then take it to a shop for the final adjustments.
      Slims
        Originally posted by ezcruisn71 View Post
        The reason they don't know how to adjust your car is because most of the modern day cars don't have many adjustments that you can do. Most of your alignment shops will only check you caster and camber and they will usually only set you toe and nothing else.
        Well yeah, that's pretty much what I was getting at. Most shops with "sophisticated laser alignment" systems rely on a computer to tell them what bolts to turn and how far (meaning they personally don't know squat about doing an alignment).
        Jeff, is this the place?
        http://www.manta.com/c/mm7xlpf/slim-...nt-hotrod-shop
        Any idea how much they charge? I'll give them a buzz later on in the week if this is the right shop.
        Thanks for the input guys.
          that is the place, I've never been there personally but lots of guys on Motown are very happy with their work. I'd say ballpark of $80-100
            we have a Hunter laser alignment machine in Madison Heights.
              Great question....will be needing the same thing when mine decides to roll.
                slims or i forget the name of the place in brighton.
                I wish i could do some. Cant bring everyones car into work though. My buddy used to work at bakers and did all the custom stuff. Since he left they dont wanna do it anymore. getting hard to find a shop that will touch stuff. I know of shops that wont even adjust rear
                  Kovachs?
                  In Brighton?
                  My dad had his Bird aligned there, and I had my car done there after the engine swap, happy with both.
                  1996 Base Model
                  +2 cylinder mod
                    yes.
                      Originally posted by jderry View Post
                      Kovachs?
                      In Brighton?
                      NICE!! Hometown....wont have to crawl too far
                        harold's frame shop on Grand river just west of Novi Rd in Novi. They're the ONLY place I use for front end work and alignments. 248 349 7550
                        When in doubt, Whip it out !
                          yes.
                          I think they do good work, prices are good too. Plus they're less then 10 minutes away
                          1996 Base Model
                          +2 cylinder mod
                            Well on the other side of the State In Kalamazoo there is Roberts Corvette I took my car there cause I was pretty sure my torque arm was out of adjustment and they did a great job with the alignment, they have an old school manual alignment.
                            1998 Pontiac Trans Am LS1, Ram Air, White with custom Ghost Flames, Black Leather Interior, T-Tops, T56 Trans, 4.10 Rear End, Spohn Adjustable Torque Arm, Line Lock, Kooks Headers, Kooks ORY Pipe, SLP Loudmouth II catback, LS6 Intake, K&N Air filter, Centerforce Dual friction Clutch, Lowered and "Conklinized"
                            Pioneer D3 HU, Infinity Reference 6.5 componets. Kenwood KAC-9104 1800w AMP, Kenwood KAC-8404 600w AMP, Subthump Stealth enclosure, PPI PRO104 2000 watt DVC Sub
                              plus everything is drive on and drive off, the lifts are flush with the shop floor, so no worries on ripping or damaging gfx peices, they always done my front work when I lowered my trucks.
