Poly vs. Rod Ends
    I dont think it really matters IMO. But I would get relocation brackets for sure. Thats going to make more of a difference than getting just control arms would.
      Originally posted by 9T8W66 View Post
      Poly bushing do not articulate rod ends or roto joints allow articulation.
      ...meh
        Rod ends wear out and get very noisy if you DD them. They are great for race cars though
          i went from the poly bushings to rod ended and i didnt notice any difference in driveability or noise at all
            if you are road racing or autocrossing having articulation is important.
            Fred if you want a set of tubular LCA's ill sell you mine because I want to switch to rod-ended for the above reason
              depends on the current ride height of the car and if the brackets adjust the angle of the LCA closer or further from the optimal angle. My car needed them when i had back seats and a sub/amp, but now that its sitting higher they would probably cause the car to hit the ground too hard.
                I have polys here, and just doing those, eliminated 90% of my wheel hop.
