View Post
Torque arms: body mount vs trans mount
Don't ask, don't tell! But seriously James, my car is quieter now than with the trans mount TA.. Or maybe I just got used to it and don't notice it anymore..Originally posted by WMCCjames View PostYou smoking something Larry?
i never noticed any more noise going to a body mount vs a tailshaft mounted. people seem to recommend 3 point sfc's with a body mount for added strength.
that trans cross member mount looks sweet im gonna have to look into thatsigpic
The LS1 or Go Home Crew
ASE master certified
thats what i useOriginally posted by Emulsifide View PostI'm surprised nobody has mentioned the transmission crossmember mount. I have this for my car:
All the benefits of getting the arm off of the tailshaft AND the benefit of a full length torque arm.
TA is a ladder barOriginally posted by kyleozzie View Posti vote get rid of that peice of crap TA and do a mini ladder-bar setup
lol
well my car will be used for handling as well as straight line.
the crossmember mount looks ideal, but im guessing its pricey. The other concern I have is my exhaust being in the way.-Joel
where does a full length body mount connect at? are you guys referring to one using the relocation bracket? I mentioned that in my first post and if thats the case you usually use a full length tailshaft mount T/A on those don't you?Doing less with more
CorrectOriginally posted by DETROITMUSCLE View Postwhere does a full length body mount connect at? are you guys referring to one using the relocation bracket? I mentioned that in my first post and if thats the case you usually use a full length tailshaft mount T/A on those don't you?sigpicTurbo Charged LS1/T56
InActive Member
- August 29th, 2006
- 1456
- Josh C.
- 1997 Z28
- Fraser, MI
- Electro-Mechanical Engineer
I have a question, The UMI trans mount model says it is set for -2 degrees for optimum traction blah blah blah then notes that the -2 degrees is for stock height vehicles. Does that mean that if I want to lower my cars rear height I need to buy an adjustable model to keep that -2 degree set-up?The Chevy Camaro was built with a single purpose in mind which it executes flawlessly...Going very very fast in a straight line until your hair catches on fire.
I would recommend an adjustable to anyone to begin with, but yes that does mean that you could possibly be off if your lowered.Doing less with more
yea, same way a lowered car needs relocation brackets to maintain proper geometry and direction of forces.-Joel
Regular
- December 4th, 2009
- 131
- Mark S.
- '94 Formula, '94 Astro LT1
- Byron, Mi
- Senior Designer 3D CAD using UGNX at GM's Milford Proving Grounds
I am considering the UMI or BMR crossmember mount myself. I replaced the broken trans mount with a poly unit when the gears were done and hate the vibration. Stan at EVI said the crossmember mount is a good fix for that as I can then go back to the factory hydraulic mount. This thread was very timely as I was going to ask the question before I found the thread... Thanks guys!
Mark2002 C.E. WS6 RA TA- Yellow #190 of 2391
1995 GMC Sierra Custom Pickup-White with pearl blue stealth flames
1994 Formula V8-Red
2000 Monte Carlo SS-Galaxy Silver
2001 Astro- The wifes DD
2004 Astro- My DD
1992 Astro (291K) Gave to my brother-in-law... still going strong
