Cornering, something doesn't feel right
  • Cornering, something doesn't feel right
    Late last summer driving my Camaro I noticed it was starting to feel a little loose I guess on the corners and curves. I've taken it easy since then and so far this spring it still feels that way. When I take a mild curve on the highway or road the weight really shifts to the outside. I don't remember it being this way in the past. I don't feel comfortable going into a curve anymore and I should. The car feels like its leaning instead of staying tucked and low like it used to. I'm thinking maybe the struts/shocks are bad, anybody else have any ideas?
    It could be that it could also be a broken sway bar link.
    — Thomas Jefferson
      yea make sure the sway bars are good. It also wouldnt hurt to get some subframe connectors.
        looked at the sway bars this weekend, they look fine.
          maybe its time for an upgrade then
            Yeah, probably, but I can't imagine those weakening enough to make the car feel different.
              20 bucks says you need new bushings and ball joints.. im needing new ones too.
              -Im Ron Burgundy?
                yeah make sure the bushings are ACTUALLY there. I went to change the brakes on my car, and the passenger side bushing was 100% missing, nothing was there. Just the sway bar chillin a few inches above where it was supposed to be bolted down. On the driver's side, the sway bar was rusted to where it bolts down, but when I felt the bolt for the bushing, it was literally just resting in the hole, the middle of the bolt was corroded straight through.
                  Dude. were you at Wild Woody's yesterday?
                  (suspension sucks)
                    yeah he was. He was parked... well... practically infront of you.
                      the green TA?
                        Well, I'm picking up shocks today, I'll let you all know how I come out.
                          yea the green t/a was me. showing up after a long day at work..
                          i thought that was you josh, but i was kinda zoning and forgot to say hey.
                          -Im Ron Burgundy?
                            It's totalled. I'll buy it from you as a salvage car. What else are friends for?
                            SpeedDetroit Speedshop <Owner> Detroit's Only True Grassroots Speedshop
                            http://gasfed.blogspot.com/
                            Originally posted by KuruptWS6spd
                            And yes my box is ALWAYS this clean
                              No problem, sounds like a good deal. Say $13K?
