Brake caliper dimensions?
  • Brake caliper dimensions?
    Long shot but does anyone know off hand or have access to the standard 98-02 PBR front brake caliper dimensions? Most important would be the mounting bolt spacing, but if anyone has a full dimension sheet or even dimensions on the spindle that would be even better. I want to start running some CAD models of possible caliper conversion brackets, but I can't seem to find any good dimensions/drawings to work from. Thanks!
    www.BroughtonAutomotive.com
    www.fquick.com/Camaro_Driver_19
    Figured. I guess I'll just wait and pick up a spindle off ebay to do my development on.
      I could probably dig up the bolt spread on the caliper mounting bracket if you really needed it...I have it somewhere from when I made my adapter brackets for my spindles. Or you could do a search on TGO and I bet you could find them listed there.
        Eh don't worry about it. I'd really need the distance from the hub center to each bolt hole to really be useful anyway. I'm planning on picking up a spindle/hub and a couple different rotors to play around with and get a solid bracket design down. The only thing I really have to figure out is if the 4-piston calipers are going to be enough or if I should go for a 6-piston while I'm at it. That and if I'll need a larger bore master cylinder to make up for the larger caliper volume/displacement.
          i have a set of 98+ spindles you buy me lunch and there yours
            Caliper template
            If you go to KORE's web site http://www.kore3.com/ they have all the templates for the diff factory calipers, print them off and glue it to a cardboard backing and you can check clearance's on your wheels!
              Thanks!!!
