what size slick would fit on my stock salad shooters? lol if n e 1 has n e im interested going to test n tune wed need some grrrrriip
slicks maybe
Interior Whore
- January 21st, 2008
- 6380
- fred
- 1996 Camaro z28
- U.P. and over you.
- united states coast guard
nope a 10 bolt cant handle 11.5x26 slicks
FYI i run a stock 10 bolt with a girdle...
Interior Whore
- 6380
- fred
- 1996 Camaro z28
Interior Whore
- 6380
- fred
- 1996 Camaro z28
I have always heard that it's very hard to get a radial to hook well with a sick car because it shocks the drive line so much. With a stick car I would run a full slick and with an auto car I would run the radial. But if you can get the radial to hook they will be faster on the big end than a because you can run more pressure in them.Originally posted by 1BADAIR View Postslicks do take a little shock out due to the wrinkle wall. I still prefer them over a good drag radial(et street radial or hoosier) on a stick any day
you can get a 6 speed not to shock by feathering the clutch. if you do a 5K dump in a 6 speed on a 10 bolt your gonna kiss it good bye, but if you feather it out youll be ok, plus unless you have a power adder just dumping will bog you out anyway. oh ill also suggest getting a TA cover, they are like 200 dollars and its cheap insurance! and you guys are ass half backwards... a slick shocks the system more because its a direct connection, a drag radial slips a little, and that little bit of slip is what will save a ring and pinion.1997 Camaro SS convertible #594-Gone but never forgotten
drag radials tend to wheel hop. thats kills it too. Vette guys won't even try to run a DR.
as far as slipping the clutch goes. If you have to slip it then you need better parts anyway.
to your ten-bolt
