In response to my thread a few down, my 315 nittos are rubbing. They are scrapping the inner fenderwell in 2 spots. The lower one looks like it would be easy to bend in a bit to avoid rubbing but the upper one looks like it has something behind it. The driver side(picture below) is worse than the passenger side. Is it ok to hammer those spots in a bit or should I go about this another way?
BFH to the rescue, then get some 3M under coat spray from Autozone and cover it up.
Perfect fix right here
1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
2015 Silverado 2500HD 6.6 Diesel
2010 Corvette Z06
"The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
Thanks for the quick replies guys. I pounded each side in and I think I should have it, but I'll double check tomorrow. I got them pounded in in time to make it for ice cream so that was a huge bonus to the test drive.
hmm... how is kolin (tastyZL1) running 315's no problem. however when he bumped up to 335's they rubbed. he has a '00 SS. and it does not appear to be hammered in... spacers?
A friend of mine want to run 315's on his car also...what wheels are you running? Do you know what back spacing/off set?
i was reading ur sig eric n i was wondering if u had any recent pics of ur car with the cowl hood and ss spoiler. its the same set up i want to run on my car when my car gets over-hauled this winter, jw how it looks
I've got 315/35/17 Nitto 555R Drag Radials on 17x9.5 speedline ZO6 wheels. I was hesitant running the 315's on a 9.5 wheel, but it seems that nittos run a little skinnier. I'm not sure on the offset/back space but they are factory ZO6 front wheels if that helps any.
here's the mild bulg on the 9.5
thanks fred
