Has anyone replaced the front control bushings on a 4th gen Firebird/Camaro? How did you change them?
Replacing Control Arm Bushings
the first side i pressed them in with a vice and it bent them and i took a cheisel and fixed them but when i did the other side i cut a C basically out of some metal to go inbetween the control arm so it didn't bend when i pressed in the bushing. you'll see what i mean when you look at itsigpic
The LS1 or Go Home Crew
ASE master certified
hammer, they come pretty easy its just the reinstall part thats a pitaOriginally posted by freakshow View PostHow did you remove the old ones? Did you use a press or did you go with the burn em out technique?
edit ill see if i can find some pics on my camera i thouht i took some, i'd prolly do the upper ball joint as well while your at it, they are pretty cheapLast edited by Virtue; April 3rd, 2008, 06:29 PM.sigpic
upper ball joint? what is that? on top of the pig?sigpic
03 Z71 Loaded, Bose, Htd leather, etc (Sold)
00 Camaro SS A4 T-tops (Sold)
99 C5 Corvette M6 (Sold)
98 Camaro Z28 A4 Coupe (Sold)
98 Camaro Z28 A4 T-tops (Sold)
96 Cummins 4x4 36lbs boost (Sold)
- February 11th, 2008
- 1230
- Anthony M
- 1998 T/A WS6
- Grand Rapids/Byron Center
- Mechanical Engineer
If you're gonna do one, do em all. Might as well while it's apart. Man I wish I would have noticed mine b4 I did my brakes, now I gotta get in there again a different day.98 Trans Am WS.6
Cam
Heads
Intake
Full exhaust
More mods to come
its on the upper control arm and points down and connects the thing that has the hubOriginally posted by b.lee View Postupper ball joint? what is that? on top of the pig?sigpic
ball joints will be cake, you can get the lowers out with a bfh, i used a press to install mine, the hot a hand tool that can do it as well, uppers are easy just grind the rivets off.sigpic
Originally posted by roadblaster View PostUse a chisel, hammer & blacksmith's forearm to collapse or cut the bushing shell into a C shape. This will relieve the interference fit so you can tap the bushings out of the arm without hurting anything. Ya, i know what i'm talking about.
thats what my dad did on his fbody.
