Aftermarket Torque arm users.....
  • Aftermarket Torque arm users.....
    Going to be getting an adjustable torque arm...probably UMI when I get my new rear end. So the question is.....trans mounted or chassis mounted. They say you get alot of road noise/vibration with the chassis mounted one, which is not cool for my car cause it spends 99.9% of it's time on the street. Anyone here running a quiet chassis mounted torque arm?
    Decoupled torque arm James, you know you want to.
      No I don't.
        I don't know anyone using an aftermarket unit on a 3rd gen but I've heard the same thing about road noise with a chassis mounted unit.
          3rd and 4thgen's are the same unit.
            Oh.... I know a few guys running aftermarket TAs on 4th gens and all are UMI pieces. Haven't heard anyone ***** about them yet.
              depends on what you want to do. A short arm(chassis) will hook much better. If you drive, roadrace or X cross get a full length. A short arm can and will cause wheel hop under severe braking but it the best way to go for drag racing
                This is a pretty cool site: http://www.xse.com/leres/ss/t-arm.html
                Somewhere in there I've read he was getting a clunk when he had the chassis mounted T-Arm installed.
                If a trans. mounted T-Arm is good enough for Phase III GMMG Camaros, I'd feel safe using one with my little motor.
                88' Trans Am 350 TPI
                  well i used to have a BMR trans mount TA, it was pretty loud with the road noise...i now have a chassis mount S and W piece and i think it's quieter. i don't think either one or the other is all that much different though
                  1998 Camaro SS Bullseye Turbo
                    thats interesting... im wondering if chasis mount noise is as mythical as poly trans mounts causing vibration - if anything my car has less vibration after switching from a brand new LS1 mount. Ive not felt one vibration yet.
                      Yeah, I will definately be using a full length arm no matter what. Short arms are not for me. I am most likey doing a trans mount design, they say you don't really have to worry about breaking the tailshaft until your 60ft's get down into the 1.5 range.
                      I was set on UMI but I looked at the BMR arm and like it a little better due to the snout design.
                        I run a spohn chassis mount arm on my 97. I have a chromoly rod end and does have some noise when beating on the car but I think it is due to the chromoly end.
                        67 Coupe Corn fed 502BBC 4L80E 371WHP/367FT lbs torque
                        70 Pontiac Lemans Vert, GTO clone, 427BBC and 7000R4
                          yeah ive got the chassis mounted one as well, it doesnt seem very loud to me at all. It would clunk and i had vibes initially, but i needed to tune in the angles a bit
                            For vehicle dynamics sake, get the long one!!
                            Also, something to think about is to have a round tube as the end and insert a grease fitting. This will allow it to twist in the bushing as the car rolls. If you just have a poly mount it wont allow the torque arm to slip and this will put a bending/twisting load on the torque arm
                              I have a BMR T.A. and it came with a big tube of synthetic grease for such an application. I've had it out a couple times since I installed it and the gease is still there so I think a fitting would be over-kill.
