Do I need a disclaimer? or it is assumed that I am not responsible for your actions?
This How to will cover two methods to remove a broken bolt.
Method 1
(This is a good method if you think the bolt might break, so it can be removed in one piece. It also applies to studs, as well at fitting as this how-to covers.)
Tools Needed
-Gloves
-Safety glasses
-Torch
-Vice Grips/socket/wrench
1. Secure the item in a fixed position. For this item I clamped it in the vice and as you can see someone already TRIED to remove this fitting as it is no longer a hexagon.
2. With your gloves and eye protection on, fire up the troch and get the area around the stuck piece glowing red/orange. Be sure to distribute the heat equally around the stuck portion. IMO the heat breaks the corrision bond more so than the metal expanding.
3. Quickly turn off the torch and grab your vice grips. Grab the fitting/bolt and it should break loose. Somtimes it requires wiggling it back in forth but it will break free.
4. The finished product.
Method 2
Tools Needed
1. Gloves
2. Safety glasses
3. Welder
4. Nuts and washers
5. Open ended wrenchs/sockets
6. Wire bush/ sand paper
This method works well for bolts that are broken off flush in the part.
1. Clean off the area off to get rid of any rust/impurities with a wire wheel, abbrasive disc, or sandpaper.
2. Find a washer that fit snugly around the size of the broken bolt. (Some people skip this step but I feel a washer gets better penetration to tbe bolt vs welding through the center of the nut which is not the easiest)
3. Weld the washer to broken bolt
4. Place a nut on top of washer.
5. Weld the nut to the washer. I like to weld the nut internaly as well as externaly where it contacts the washer.(kinda hard on this example)
6. Let the nut cool down for 30 seconds, and loosed the nut with a socket/wench and this should be your final product.
Method 1
Tools Needed
-Gloves
-Safety glasses
-Torch
Method 2
Tools Needed
1. Gloves
2. Safety glasses
3. Welder
4. Nuts and washers
