Project 1988 T/A GTA
  • #61
    The was told the roller rockers I bought were 1.5 ratio. Further research shows that the idiot had 1.6 rockers. So, how bad is it if I use the 1.6 rockers?
    Do do I have to spend bucks on nice 1.5 rockers so I don't over cam the engine?
    1988 Trans Am GTA 355 TPI/700r4 Summer/Fall Driver
    2001 Nissan Pathfinder V6 4x4 Loaded and Rusty Winter Beater
    Always Missed
    1999 VW Passat 1.8T/5-speed
    1996 VW Jetta VR6/5-speed
    1988 Mazda 626 5-speed 300,000 miles
    • #62
      Lift would be 520 and 528 with 1.6 rockers. A good set of valve springs will handle that lift for a long time.
      • #63
        Awesome. I went with some comp beehive springs. Just didn't want to put those 1.6s in there and blow the valves/pistons
        edit: comp cams 26981 for the springs.
        Always Missed
        • #64
          981 have an install height of 1.700, they coil bind at 1.115 (@ .585 lift) which means you're going .003 under Comps recommended clearance of .060. Will it cause a problem? Not likely in a TPI build.
          If you can't hit the 1.700 installed height (a little over would be ok in your situation) then you will need different valves, or retainers, or machine the pocket depth in the head.
          • #65
            She'll poop out at 4000 rpm anyway so I'm going to roll with it. .003 within spec is still in spec. Valve float would probably be monstrous at 4000+ anyway with the 1.6rr.
            Always Missed
            • #66
              You're .003 too close to coil bind, out of spec. Should be ok though. Highly doubt you will see valve float under 5000 but can't say anything about longevity of the springs.
              Just make sure you get the installed height spot on or a little over 1.700
              • #67
                This was all done within 10 minutes. Oh the vomit is everywhere.
                BadlandzHPE 3 inch custom Cutout = $170
                Hooker Aerochamber = $370
                Hooker Headers = $424
                Hooker y-pipe = $264
                Magnaflow Cat = $169
                Always Missed
                • #68
                  Ouch...a $1400.00 day. Haven't had one of those since I bought the car itself.
                  • #69
                    Better than Christmas morning when I got home from school tonight.
                    Always Missed
                    • #70
                      Nice!
                      Sound clip when it's installed, please.
                      • #71
                        Got some work done in the shop today. I will need to get different centerbolt valve covers. I drilled out the insides, but still not tall enough for my roller rockers.
                        Always Missed
                        • #72
                          I have a set of valve covers that would probably work for ya!
                          "Project Shadowfax" <- Clicky Clicky
                          • #73
                            I think I bought the stock ones from you! What do you have that would be taller? I'm finding ones for $180+ (bulls**t) for only 1/4" gain in height.
                            What ya got?
                            pictures?
                            Always Missed
                            • #74
                              Quick question:
                              I need some new roller lifters. Would GM Part#: 12499225 work for my application? They are for LS engines, but I think these would work and would like some conformation.
                              Always Missed
                              • #75
                                they will work
