Nocooler's 00 Firebird
  • 2" shock extensions on the way
    Figure with that and removing the isolater I can get almost 4" of downward travel.
    2000 Formula
    fixed slow junk
    • They didn't have the black extensions to begin with?
      • Originally posted by 1BADAIR View Post
        They have the adapter that reduces it to 3/8 or what ever for the bolt hole.
        2000 Formula
        fixed slow junk
        • hmm. mine drop like 5 inches when i jack the front up
            Other way Larry! It's topping the shock out on extension
            2000 Formula
            fixed slow junk
            • mine needs limiter straps. they drop too much.
              • Lowered?
                2000 Formula
                fixed slow junk
                • No more racing this year - one of my rear shocks has zero compression.
                  I thought it was fine since you couldn't push the rear down when they were tight. But it's junk. Guess the anti-roll bar was working.
                  2000 Formula
                  fixed slow junk
                  • Originally posted by Nocooler View Post
                    What are you going to put in? I'm thinking of swapping, to those vikings that Jim has, this winter..
                    • Vikings or afco's.
                      Vikings are the best bang for the buck.
                      2000 Formula
                      fixed slow junk
                      • Ya you can't really beat vikings for the dough. .. I got dual afco coil overs front and rear on mine and I probably have around 1600 between shocks springs hardware and Torrington bearings.
                        You have big money though... get some penskes
                        Sucks tto hear Jeremy. I'm getting my car out for the first time in 3 years next Friday!
                        • viking rears are on the way - bearing mount lower and threaded body incase I want to go coil over in the future.
                          Eric@MWC said they should be here by friday - if the weather holds I'd like to make some hits on Sunday.
                          2000 Formula
                          fixed slow junk
                          • I take it you already have transverse shock mounts? I haven't seen the viking up close but anything bearing lower seems to need em.
                              Yes I have traverse mounts with bearings in the QA1's - Eric ordered the vikings with bearings, it's no extra cost when ordered new
                              2000 Formula
                              fixed slow junk
                              • U will be very happy with those shocks I like mine. I have to work this weekend so no Stanton for me going to try Milan Friday night see what she will do on a 150 shot
